12.30.2009, 02:24 PM
there is the problem, i cant gear up 63/26 is the best i have found
losi makes a 59 tooth spur but the motor cant get close enuf to mesh right (it hits the transmission) and i havent found a place that makes over 26T pinions in 6mm
You can get the tdr colleted pinion adapter with a 6mm collet and then get a 25-30t pinion gear from rcm. Use that with the 59t spur and you will have plenty of gearing options.
