Semi Pro
Semi Pro's Avatar
12.30.2009, 05:36 PM
Your car list shows an lst w/centre diff......? With that you can gear it for speed runs.
that my other truck
this is for my new xxl, linc i was thinking about going with a tdr cullet and mikes 2speed gears but that still puts the top speed under 60mph
12.30.2009, 06:52 PM
that my other truck
You can run taller tires! Pretty sure sdp-si had 6mm bore pinion gears over 30t, and just run a lst2 63t plastic spur since the sdp pinions are not hardened.
Pdelcast
Pdelcast's Avatar
12.30.2009, 08:10 PM
Well, I hadn't had a chance yet to get the "official" OK from Steve Neu to market the 1717 as a "Castle/Neu" design. It is now official (as of yesterday, I think.)
So the 1717 will be sold in the future as a "Castle/Neu" design.
The design is very similar to the 15 series stator, just scaled up a bit and a couple minor changes.
Patrick
Patrick del Castillo
President, Principle Engineer
TexasSP
Something, anything, nothing
TexasSP's Avatar
12.30.2009, 08:28 PM
Straight from the lips of El Jeffe!
www.cubicle101.com
johnrobholmes
johnrobholmes's Avatar
12.30.2009, 09:46 PM
Patrick
Changes that you made yourself?
---JRH---
shaunjohnson
i pwn nitro
shaunjohnson's Avatar
12.31.2009, 02:00 AM
Originally Posted by johnrobholmes View Post
Probably because patrick designed it himself
in his sleep
  Send a message via MSN to shaunjohnson
Pdelcast
Pdelcast's Avatar
01.01.2010, 06:58 PM
Yes, by scaling the stator we needed to move some iron around a bit to keep saturation levels correct in the stator iron.
Semi Pro
Semi Pro's Avatar
01.02.2010, 09:52 PM
thats good news, do you have a link
mike is out of the 30 tooth 2speed gears
