FLM half case and G1 single speed.
RC Fan 4 Life
FLM half case and G1 single speed. -
02.05.2006, 12:01 AM
for thouse of you who have this does using only 4 screws hold the trans in good? Did you only use 4 screws to hold down the chassis braces?
Do you need to put any grease in the trans?
12:02 AM
RC Fan 4 Life
Find all posts by RC Fan 4 Life
2
squeeforever
02.05.2006, 04:42 AM
i think a little grease wont hurt. as for sturdiness i think it should be just fine.
squeeforever
Find all posts by squeeforever
3
nitrostarter
02.05.2006, 12:44 PM
It should be very sturdy, 4 screws into a CNC'd aluminum case instead of a plastic case. The aluminum wont give or strip out like the plastic might.
N. Rustler conversion
nitrostarter
Find all posts by nitrostarter
4
squeeforever
02.05.2006, 01:03 PM
just remember to use thread locker.
squeeforever
5
RC Fan 4 Life
02.09.2006, 11:16 AM
Do you need to put any grease in the trans? If so what kind that i can get from a auto store.
RC Fan 4 Life
6
squeeforever
02.09.2006, 08:40 PM
no grease. i would just put a very little on the gears if you run a steel idler. you wont need much at all. i just use associated black grease.
squeeforever
7
Serum
02.10.2006, 06:43 AM
I use dry lube in the transmission.. grease won't stay put.. at 7000 rpm, it wil fly off..
Serum
Visit Serum's homepage!
Find all posts by Serum
Linear Mode
Switch to Threaded Mode
