Righto guys. Ill be purchasing the Slice chassis for my slash, & because the tranny is reversed, ill have to reverse the throttle position. But because ill be using a sensored motor in SmartSense mode, will this still work with a sensored motor?
Yes it does - I had to reverse the direction for my Ve8 - I'm using the Tekin T8 and MMP. Just reverse motor direction using Castle Link and you'll be set.
In the beginning the Universe was created.
This has made a lot of people very angry and has been widely regarded as a bad move.
Hey Marvin,
What T8 Motor are you running? How's that working for you?
I've been wanting that same setup myself.
I've been running a Novak 6.5 Sensored Motor with my MMPro and it works great.
I'm running the 1400KV on 6S. I've got 3 additional caps (35V, 220UF, 105° each), and I'm not using the onboard BEC. I haven't had much chance to test it yet - it's too wet and cold over here, not to mention that there are no 1/8th races going on in the winter.
It is powerful enough to wheelie, and is pretty quick, so it looks good.
