sikeston34m
sikeston34m's Avatar
02.06.2010, 11:38 PM
Originally Posted by jzemaxx View Post
Does anyone know what the comparison in sizing is between NEU motors and these new Scorpion motors. I hear they are excellent motors. I was hoping they had a 1400KV motor I could use in place of a 1515 3D to try on 6S. But not sure how you would compare the two. The HK3026-1400KV looked interesting and also the HK4020-1390KV. Are they smaller or bigger motors. Look at the specs...the continuous watts seems to be higher then the NEU 1515's and they are 8 pole motors instead of 4 pole.
Those are outrunner motors.
The 3026 has a stator that is 30mm in diameter and 26mm long
The 4020 has a stator that is 40mm in diameter and 20mm long
See the pattern?
