George16
Supermaxx
George16's Avatar
02.21.2010, 11:20 AM
The 44T spur will hit the x-braces if it sits low unless the G3 chassis is a bit wider than the G1. This is the reason why I made the mounting plate. I also tried a Kyosho 46 and Ofna 48T spurs but the 44T works the best unless I use a CNC in making the mounting plate holes.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
