Rivermaxx
02.21.2010, 12:25 PM
Beau, what's the gap between your x-braces? I'mm just curiios if it's the same compared to the G1 chassis.
Edit:
Mike needs to make some more of his mount. I need at least 1 more to convert my supermaxx to brushless.
I cant find my good caliper but with my cheapy pocket chum its a hair over 46mm also, probably the same. Like I said the verticle triangle area is where I put the spur gear and it is tight probably less than 1mm clearence on either side.
