maxxdude1234
maxxdude1234's Avatar
02.11.2006, 11:57 AM
A 9XL on 12 cells will be very slow. I would agree with squee, an 8XL and 9920 are definately the way to go for 14cells (and should be good for 18cells). The 8XL has a 5mm shaft - but new pinions wont cost much, and if you get the gearing right first time you should only need 1-2 pinions. Hopefully someone with this set-up will reccomend you a good gearing
