03.02.2010, 04:39 PM
Originally Posted by ClodMaxx View Post
one other thing that you probably know already, but it can't hurt to reiterate: if you're using loctite, make sure you give it at least 24 hours to cure/fully dry. anything less than that, and you risk it having the same holding properties of milk.
Yep, and it probably helps to clean most of the old stuff off.
