Cc 2200 Bearing Size?
brushlessboy16
brushlessboy16's Avatar
Cc 2200 Bearing Size? - 03.17.2010, 06:54 AM
What size bearings do the big castle motors use?
Benji
03.17.2010, 01:42 PM
Not 100% sure, 5mm x 16mm x 5mm
Thomas Porfert
Thomas Porfert's Avatar
03.17.2010, 04:06 PM
+1 for Benji. 5 x 16 x 5.
andreazinno
03.18.2010, 01:16 PM
Hi, same size also for 1520 ?
Bye, Andrea.
03.18.2010, 07:19 PM
I believe so- its the same diameter motor and shaft, just longer.
Thomas Porfert
03.18.2010, 11:20 PM
I'll double check tomorrow and let you know. I'm pretty sure neil is right, but I want make sure. I'll get this information posted on our website as well; it should have already been there. My bad.
Out of curiosity, were you needing new bearings for the motor? So far I have heard of less than a half-dozen bearing failures with these motors; just making sure there's not a problem we don't know about or if you're just stocking up to be safe.
Thomas Porfert
Castle Tech Support
andreazinno
03.19.2010, 04:50 AM
Thomas Porfert
Castle Tech Support
Hi Thomas, my question was just for curiosity and, eventually, to get some bearings to be used as a spare.
Besides, I wonder whether I can get some hybrid bearings (for example the ones from Boca Racing) to have even better performance with respect the factory bearings.
Bye, Andrea.
Thomas Porfert
03.19.2010, 06:04 PM
All of the 1500 series motor share the same size bearings; 5mm x 16mm x 5mm.
Thomas Porfert
Castle Tech Support
