scarletboa
scarletboa's Avatar
04.12.2010, 12:59 AM
You should have listen to the people you asked for help. If you need a 540 sized (36mm) because of your mount you are very limited in motor choice. You should have supported RC-Monster, the company that pays for this forum, His motor mount would have let you use any motor. Good luck with the Losi esc, I haven't heard of anyone that has had good luck with them. When you choose your motor, because you are limited to a 36mm I would look for a Medusa, at least a 70mm if not 80mm long, or a Neu 14xx series. If you are going to go the cheap route make sure to get an XL motor. As for matching up motor and voltage, your gonna want to get your peak motor rpm in the 30-35k range
+1
