steveo
04.21.2010, 10:48 PM
problem solved now another question, is there a standard shock and then the 16mm bigbore if so how can i tell which i have, i'm rebuilding all my shocks and seen two different rebuild kits
el tomaso
05.05.2010, 12:24 PM
I would use a caliper and measure the width of the shocks, if they are 16mm you have the big bores. If they are less, you have the old type.
Thomas G
