Originally Posted by Overdriven
I knew I should've checked the store before I bought my 8t 2.0. I hate to be one of those impatient people constantly badgering you for a release date, so hurry so I don't have to!!! :-) Out of curiousity though, how big of a spur gear can the mount fit? Stock Losi 8t 2.0 is 50t, will I need to go to a smaller spur?
Well, in the e-8 conversions, the differential gets spun around 180 degrees. Anything larger that a 45T spur will need some grinding on the chassis or a slot cut for the gear to clear. This is the case unless Mike's new mount will provide a spacer/riser for the differential.
