notnodak
05.21.2010, 01:49 PM
I'll tell you what I did.
Get a MMM Mount, then use velcro underneath it also.
The MM Pro is just a little shorter than the MMM, so the velcro aids in holding it, plus helps take up that little bit of extra space.
Plus you have a place to mount the ON/OFF switch.
Thanks for the hint. Gotta pic?
The Pro should work great. I'm using a MM now with a 2600xl Hobbycity motor and it's fine. I do use a UBEC with it but the New stuff in the Pro will handle it all like a pro. I will be going to a Castle 2650 motor also which will be even better. As far as the two servos I'm guessing it'll be a load but with the tunability it'll work fine.
