In the stock A Arm setup, is there enough room for the added diameter of cut-down E Revo shafts
Yes, there is plenty of room, on the arm side. The front shocktower does have to have a little shaved off the bottom of the link mounts. This is what weakened my first aluminum shocktower, that broke there, for the second one I ground off the shaft . But in these circumstances, I think a little off the mount would be fine.
I pulled the diffs apart to change the outputs. I had extras from old blown E-revo diffs, and they dropped right in. I too, was expecting to see the same diff as the Revo, and was surprised to see the differences, but it seems they are where it counts.
