brian015
brian015's Avatar
05.26.2010, 08:07 PM
When I had a problem with wobbly spurs on my Rustler it was because of a defect in the slipper. Never had a problem with the spurs themselves. You just want to make certain that the problem is with the spurs, or changing to 32p won't help.
brijar
Knowing You're Hooked on RC: Priceless...
brijar's Avatar
05.26.2010, 10:05 PM
I guess it could be a problem with the slipper. I was hoping that the 32p gears wouldn't care as much about a little wobble if they still wobble. The larger teeth should have a higher tolerance for what an acceptable spacing is, right?
Brijar!!!
REVO 3.3 Conversion: 3906 trans, CC 1518, MMM, 6s Gens Ace 5k 40C, LST Diffs, Summit shafts
Slash 2x4 LCG
Two Slash 4x4s
Rustler
