Chadworkz
UE Supermaxx Addict!
Chadworkz's Avatar
06.10.2010, 09:56 AM
The CC/Neu 2200kV motor is awesome in a Revo 3.3 BL conversion, and all you need to do to clear the XL motors is run the Traxxas Extended-Wheelbase rear a-arm kit. As for the kV of the 2200 and 5S, just gear down a little bit and you will have a very efficient system...higher voltage and lower gearing is more efficient than lower voltage and higher gearing. I am geared for 40mph on 4S with the CC/Neu 2200kV motor and it is PERFECT!
-Chad
PM ME IF YOU HAVE THE BELOW:
