06.16.2010, 01:34 AM
go ahead and recalibrate the main voltage if it bothers you. Just mlower it a little so it matches the other charger.
There really is no problem and you really are mover analyzing the whole situation. Good for you, better safe than sorry, but you really have nothing to worry about.
If you can afford to upgrade to a hyperion take the plunge, you won't be disappointed.
If you use the batteries together either in series or parallel for now charge one at a time on the same charger.
If you use them seperately I tenths of a volt discrepancy is nothing to worry about.
