06.17.2010, 11:44 AM
The conversion will work fine with smaller motors. However, this vehicle is somewhat comparable to an 8th scale buggy as far as weight, size, etc is concerned, so using 10th scale components may cause overheating unless geared very very low.
JThiessen
JThiessen's Avatar
06.17.2010, 01:07 PM
Should be equivelant to what we used to run on the Revo's. Novak Systems should work OK, as may the MM.
