Castle Neu 2200kv bad bearing?
Stoomstrijkijze
Castle Neu 2200kv bad bearing? - 06.25.2010, 12:41 PM
I have a brand new MMM V3 combo with the 2200kv motor for my mbx6. I finished my build yesterday and I've been to the track this afternoon to test it.
I ran 2 lipo's with 13/46 gearing. My motor was around 63°C after each run, so temps were good.
When I came home and did a check up of my buggy I found out that there was play on my motor shaft. I compared it to my other 2200kv motor (that is 4 months old) and that motor is still in perfect shape.
I tried to remove the bearing and go to the hardware store but I can't get the bearings out of the end bells. I guess the rear bearing is still fine. Just the front one has play in it.
Anyone had this problem too?
