simplechamp
simplechamp's Avatar
06.28.2010, 09:32 PM
I would sell the Sidewinder and CM36 motor, cut your losses, and invest in a Mamba Max Pro and suitable larger motor (Novak HV, Ballistic 550, Tekin 550 if you want to take advantage of the sensored capability.)
nuz69
nuz69's Avatar
06.29.2010, 04:46 AM
I would try the CC mamba monster 2200Kv/4S 25/90 gearing, with 80% punch control and 6 timing, that should be smooth and should run as cool as can be ^^ The only cons is the additionnal motor weight ;)
The solution of desesperate heating problems is always bigger motors
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
