Thread Tools Rating: Thread Rating: 11 votes, 5.00 average. Display Modes
georgec
georgec's Avatar
06.28.2010, 10:36 AM
I have been waiting to post on the durability of the Evercool fan till I had a few races on them and after four races both are still working great! The one in the CC Blower runs all the time while the one in the MMM only comes on after about 5 min. of running and in this heat sometimes in 2 to 3 min. So far so good!
Shonen
Shonen's Avatar
06.29.2010, 04:12 PM
Originally Posted by georgec View Post
A side note on the CC Blows, when they made the fan shroud that fits over the motor they didn't allow any place for the air to exit after the fan pulls it in! So I cut away 5/8" between the two zip tie tracks leaving about 5/32" between the shroud and the motor. That way the air can exit almost as fast as it enters, taking the heat with it! Witch after all is the purpose of the blower....isn't it?
Hope this is of some help
GeorgeC
The airflow is supposed to go between the fins on the motor can. When I first got my blower I was confused about that as well but after taking it out for a run it made sense. The shrouding is there for a reason, it directs the airflow around the motor for more even cooling. It's true that squeezing that air through that small space will drop the CFM's significantly, but I'm sure Castle did their homework with this. High airflow is useless if it isn't put to work.
It does feels a bit cheaper than I'm used to for a Castle product (very stiff plastic and wires), but it does the job. I haven't had any problems with it yet, although if/when the fan dies you've shown people a replacement option
georgec
georgec's Avatar
06.29.2010, 04:39 PM
What????...How can there even be "HIGH AIR FLOW" when it's being packed up in a box and forced back through the top of the fan? With over whelming back pressure there is no air flow and therefore no heat exchange!
Shonen
Shonen's Avatar
06.29.2010, 05:01 PM
by cutting up the shroud you decrease backpressure and thus increase CFM, but because the shroud isn't directing the air around the motor, you can't cool the motor as effectively. the air is supposed to flow around the motor, between the shroud and the motor fins. If you wanted maximum airflow, you would just ziptie the fan to the top of the motor without a shroud.
What you're effectively saying in PC terms is that instead of having system/cpu fans inside the case, it's much better to take out the fans and instead put the entire case in front of a fan moving huge amounts of air. Sure, backpressure will drop CFM's but what's the point if what CFM's you have are not being used effectively?
georgec
georgec's Avatar
06.29.2010, 05:16 PM
By opening the bottom of the shroud the air flow is allowed to move across a larger portion of the motor with greater cfm therefore taking more heat with it!
georgec
georgec's Avatar
06.29.2010, 05:26 PM
If you want to relate this to a cpu, you can have as many fans inside the box as you want but if you don't have fans removing the air from the box you are doing nothing but circulating hot air in the box!
Shonen
Shonen's Avatar
06.29.2010, 05:44 PM
The shroud is there for a reason. Like I said earlier, if you wanted maximum airflow you wouldn't use the shroud at all, just ziptie a fan (probably a larger one) on the top of the motor.
Also, what you said about the pc (not cpu) is entirely correct, it's not the best analogy but that's what I've been trying to tell you. The shrouding ducts the fan so it will push air across the maximum amount of motor surface area while keeping a decent amount of airflow. Pull air through the case (ie. what has to be cooled) even though there's vents, cabling, etc. in the way rather than blast only one part of it with high speed air.
phatmonk
RC carbon junkie
phatmonk's Avatar
06.29.2010, 08:01 PM
My Blower snapped when I tightened the zip-ties too tight.My fault,but its not that sturdy.Can a cooler motor effect the ESC performance/temps?
SC8-E RCM MMM CC 1717
Slash 4x4 MMP CC SC 2400
georgec
georgec's Avatar
06.29.2010, 08:13 PM
Well the bottom line is I'm not cooling a "PC" I'm cooling a 1/8th E buggy motor under race conditions. Before the mod to the shroud my motor temps after a 15min main ran between 170/180f after 160/170f but I believe I can do better than that by taking one of these and removing the nose piece and splitting the rest in half. With this fan bracket I can mount a 40x10mm fan instead of the 30x7mm. The reason I know this will work better is I already have this setup on a Tekno 2200kv motor and it temps at 150/160f after a 15min main.
Here is the Tekno setup on my O'Donnell Z01-Be
georgec
georgec's Avatar
06.29.2010, 08:15 PM
Yes! The cooler the motor the more efficient it is, not to mention longevity!
Shonen
Shonen's Avatar
06.29.2010, 08:28 PM
well the pc was an analogy. either way, a larger fan will do a better job of cooling...are the Monster and Blower fans the same?
georgec
georgec's Avatar
06.29.2010, 08:32 PM
I'll post up some pics after I have the new fan bracket mounted up. And I don't think it's your fault that the bracket breaks, plastic that thin has no place on a 1/8th buggy of truggy. That's why I'm making one out of aluminum.
georgec
georgec's Avatar
06.29.2010, 08:33 PM
Yes 30x30x7 5VDC
Pdelcast
Pdelcast's Avatar
06.29.2010, 08:36 PM
George,
I'm interested in your long-term testing of the Evercool fan. Keep us posted! It's not any more expensive than the fan we are using now (in high quantity...)
We do have a new version of the fan we are using now -- they made some changes to the fan to make it more durable (on the electronics side...) but it seems there is some variation in the blade durability.
I'll talk to our supplier about beefing up the blades a bit on the 30x30 fan.
Thanx!
Patrick del Castillo
President, Principle Engineer
georgec
georgec's Avatar
06.29.2010, 08:42 PM
George,
Thanx!
Will do Patrick. This is only the second fan in three seasons, not bad considering the beating these things take in a race day
