07.08.2010, 11:20 AM
I would assume so, so long as there is sufficient space for clearance underneath the spur ( between spur and chassis I mean ), otherwise a slot in the bottom of the chassis/ diff mount woudl be okay. Truth be told though I've NEVER seen a broken plastic center diff unit/ mounts, never. That would mean you could buy a whole unit complete with actual diff and just drop it onto the mounting plate, drill 4 holes and bolt it in place...
