08.08.2010, 03:18 PM
Originally Posted by Dj_Sparky View Post
I plan to use Mamba Monster with 6s lipo. Low gearing of course.
Anyhow...
Both the 2 gear on the input shaft and 2 gear on the middle shaft are locked together. The gears on the input shaft are 1 solid unit. :S
The 2 gears on the input shaft are likely one solid piece. The other two gears have to be seperate, as they rotate at different speeds. The non clutch gear is supported by a one way bearing, and the clutch hold the other gear in place. They will be removable, somehow.
Dj_Sparky
08.08.2010, 03:48 PM
They are seperate, but the first gear (On the middle shaft.) is attached to the centrifugal clutch by a one way bearing. The 2nd gear is a part of the centrifugal clutch housing - The one I pointed to in the pic you posted.
