Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.21.2010, 07:08 PM
Why ?
Bmr4life
08.21.2010, 07:32 PM
Why ?
So you can try out different lengths without undoing all the work you've done cutting the ends. You can cut somewhere in between and make the panels removable.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.21.2010, 07:51 PM
The idea sounds good but thats about it I'm afraid. Thats a TON more work ?
Also would make strenth issues I'd think, Thanks but no thanks.
thzero
08.21.2010, 11:57 PM
Yeah, looks a tad long anyways. :)
What did you cut the plates out with? Jigsaw?
Thinking of chopping 3-1/4" off the front, probably get started on that first thing in the AM.
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.22.2010, 09:33 AM
See post #9
Shortening today then hopefully getting a LOT more done ??
Jahay
08.22.2010, 01:37 PM
it does look great, but it would benefit from being shortened. Keep us posted with pictures.
im just in the process of rebuilding my truck and i just cant find the time...
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.22.2010, 05:23 PM
Due to unforseeables I wasn't able to work on the chassis as much as I hoped to today.
But, I did have a hellava brain storm thanks to JPOPROCK during a email conversation.
I will no longer be using the Flux tranny, I'm going with something a bit better.
I will post pictures when I get a chance to get back into the workroom and make some progress, hopefully Tuesday.
_dV
08.23.2010, 04:23 AM
Look forward to seeing what your up to.
Pity your gonna chop the length, would love to have seen the 24 incher with the front wheels in the air
Jahay
08.23.2010, 05:16 AM
i would have liked to have seen the size of the drive shafts you would use haha :)
jpoprock
jpoprock's Avatar
08.23.2010, 10:18 AM
Yeah Jeff, I feel your pain with shortening the chassis. I had a penis reduction surgery not long ago, and you really start to second guess your decision after it's too late.
Yer welcome for the "idea". Lord knows you've given me plenty too!!
  Send a message via Yahoo to jpoprock Send a message via AIM to jpoprock
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.23.2010, 10:36 AM
You boys talking about the same thing ^^^^^ ????
Jason, I think the WB at 22" will be more than enough. I origianlly wanted a tick longer to be a bit different but the added weight and lenth I've determined is not needed nor in best intrest of the build.
thzero
08.23.2010, 12:00 PM
That's what she said!
UPDATE w/PICs
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
UPDATE w/PICs - 08.27.2010, 09:00 PM
OK, I've shortened the chassis down to 22" so WB will be a tick longer.
The motor I've decided on is a 1521 1050kv and should work nicely with 8&10S, a little worried the motor might be a little underpowered. I was hopeing to use my 1527 but 1500kv is way to much for 10s.
I've installed the transmission, looks a little awkward but the LST tranny is far superior over the Flux trans. It has more gear reduction and a much better slipper clutch assembly. With the trans centered the outdrives are still off set a bit so instead of making Dogbones I will home fab CVD's instead.
All the brackets and stuff I made nothing is nut&bolted together, I tapped all connections in 4mm except a few things which are 3mm.
Yes I have a brace for the tail end of the motor to help support, not shown in pic.
Q; which end should the CVD be on, The Trans or Diff ??????
I still have a loooong ways to go yet, I have to install the battery tray and I have LOTS of finish work to do to the chassis (cut outs to lighten it, file and smooth all edges, make openings much neater and tidy up everything.
Was going to shoot for a 60F/40R weight distribution but not real sure where thats gonna lead with how I have stuff now ???
Dual 4s and/or 5s packs will weigh in a lot and hopefully get the balance to where it needs to be ....
Still trying to decide on a "finish" for the chassis or go raw aluminum ???
josh9mille
josh9mille's Avatar
08.27.2010, 09:15 PM
Heck, I couldnt afford the penile reduction surgery, so i got the hand enlargement surgery instead
Nice looking build BTW!
Bondonutz
Fat Kid Engineering
Bondonutz's Avatar
08.27.2010, 09:22 PM
Looking at my post I really wished I put everything another inch or two forward ??? Time will tell when it's together and I pull the trigger ........
