CEN GST converting w/center diff -
08.23.2010, 08:31 AM
okay, i get my truck and started tearing down. i have run into a problem though i'm hoping somebody can answer some questions before i start buying non working parts.
i know a few people have used the matrix tr arena diff for this conversion. i was planing on trying with one i already have. i was at first going to just remove the front slider shaft and replace with a dog bone, only to discover that it is red lock tighted on and i cannot remove it and replace with an output cup. so then i try to swap the output on my diff with the output on the stock diff in the gst's trans. its made just a little different and the shaft going in is just short of allowing me to put the pin in it. now my diff is from a gs sut, but my question is will i be able to do this if i buy a cen diff from the arena? if not, my other option will be to tear into the front diff and replace its output with a cup so i can use a dogbone. i need to buy one or the other, but i really like the idea of keeping the slider if possible. my thoughts are less rotational mass, and a more solid connection than a dogbone.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
i've done some searching, and the part i have from stock diff output is gs039. the rear cup appears to be gs094. in the tr arena, its front and rear ouput cups are gs094. with this info, i'm thinking i can just pick up a tr areana''s center diff and replace the front output with a gs039 and it should be a direct swap. if anybody knows anything that would make this not work, please let me know so i don't waste any money and time going this direction.
Current Projects
CEN GST Mgm 22418
castle 1717
6s lipo
Losi Aftershock
Infinite 160a esc
Motor Not sure yet
Depending on your motor, the slider will snap sooner or later. You need to get the drive cups from Nemesis to put on the front diff and middle diff/tranny + dogbone. 3 items.
GS093 drive cup for the front diff, GS219 front drive shaft and G094 brake drive cup for the centre diff
i guess i will head that direction then. i will also have to get that slider off the front diff some how. any tips on removing red loctight? i may have to just replace the dang input gear.
basically its the input gear into the front diff where the grub screw is at. the front half of the slider is loc tight onto the input gear. i will try heat if i have time tonight after work. i guess i can try to get some pics up too of my progress.
so how did you get the slider to adapt to a center diff? or did you just use a cen center diff? my diff i already had was like 1mm away from the cen output to fit in it.
here are a few pic from tearing down a bit and cleaning.
I gave up on my conversion because I couldn't get the parts for the dogbone installation. If, as you say, the slider will hold up under brushless I will start again.
I love those tires btw. Are those regular badlands?
yes, the truck came with the stock 7.7s but i wanted to loose weight. these are ofna full offset wheels and standard mt badlands. i've had them for a long time but never really used them. i love the mean stance it gave the truck.
