Pdelcast
Pdelcast's Avatar
08.27.2010, 02:53 PM
Originally Posted by Cain View Post
I saw a post by another person who owned two mamba max pros, here is an excerpt from it:
are others experiencing this? is there a trick to proper insertion of the wire? I know Novak had to put a message about there sensor wire removal for the motor, curious if for castle MMP it needs special attention there?
Just want to make sure I cover my bases with these new ESCs.
We did have an issue with early production units, but the issue has been fixed.
Patrick del Castillo
President, Principle Engineer
ta_man
08.29.2010, 11:43 PM
Any way for someone to tell if they have a problem before the warranty runs out? Is it so obvious they fall off the first time you install/remove the sensor cable?
Pdelcast
Pdelcast's Avatar
08.30.2010, 10:11 AM
Yeah, it's that obvious.
If it ever falls off, we'll cover it under warranty.
