Strange noise comming from my monster
A RC Dude
A RC Dude's Avatar
Strange noise comming from my monster - 09.05.2010, 06:54 PM
I just ran it a few moments ago and about 5 mins into the run, i started to hear a winding noise but it was only wile staying the same speed or coasting. i heard it comming from around the motor and i took the pinion off and rolled the car down my driveway at a high speed a few times and never heard it but when i put the pinion back on and reset the mesh, it started again.
any idea what it is? i'm thinking it's a bad bearing but am not sure
A RC Dude
A RC Dude's Avatar
09.06.2010, 12:28 PM
anyone have an idea?
Dj_Sparky
09.06.2010, 01:24 PM
Maybe the motor has shifted. Do you have a CC motor? If so, you might have twisted the motor and the spikes are hitting the chassis which will warp the pitch of the motor itself, and the pinion might hit the spur sideways. Check from the sides and check that it lines up correctly.
The screw on the pinion gear might have gotten loose..
redshift
RC-Monster Square Tube
redshift's Avatar
09.06.2010, 05:05 PM
Transverse planetary solenoid is my guess.....
Gonna have to take it apart sir, we can't really help I'm afraid!
A RC Dude
A RC Dude's Avatar
09.06.2010, 06:13 PM
ohh, fun! lol always wanted to see what it looks like on the inside. other than in a picture
redshift
redshift's Avatar
09.06.2010, 06:22 PM
It's your lucky day
Welcome to initiation, put this blindfold on...
A RC Dude
A RC Dude's Avatar
09.06.2010, 07:37 PM
haha yea, wish it was for a better reason though.
is their anything i need to watch out for when i do it?
redshift
redshift's Avatar
09.06.2010, 08:42 PM
Lots more info would be helpful.
What's the vehicle, does it have a tranny or CD, what motor.
But yes check the motor, the shaft will have a tick back and forth but should not have a 'clunk', and check for resistance spinning the motor shaft while pushing and pulling on it. Where is linc to take that out of context....
And check side to side play on the shaft, again should be VERY little shuck, or none.
09.07.2010, 09:47 PM
What do trannys and Cross Dressers have to do with R/C? How much should one resist spinning their shaft? Such incoherent babble......
A RC Dude
A RC Dude's Avatar
09.07.2010, 11:24 PM
thanks guy!
redshift-i rolled my car without the pinion gear on the motor down my drive at 20-25mph with no sound. but when the pinion is on, the noise appears but is a LOT more noticable wile holding the same speed or coasting, i can't even hear it when i'm on the gas or brake much.
did you check to see if somebody put a car supercharger on your e-maxx? This all sounds very suspect.........
the only supercharger i see is the big blue brick of a battery
redshift
redshift's Avatar
09.07.2010, 11:43 PM
Mr. Dude has to learn some of the finer points. Sometimes you have to get intimate with the inner workings, poke around a bit. Occasionally some sweet soft words can coax the problems out and if you're fortunate, it'll respect you somewhat the day after.
JUST TAKE IT APART!
You could be working on it now, now, and now.
A RC Dude
A RC Dude's Avatar
09.08.2010, 07:31 PM
JUST TAKE IT APART!
no i can't...been too busy with school and all
A RC Dude
A RC Dude's Avatar
09.06.2010, 10:39 PM
thanks! it's a 2200kv mamba monster in an e-maxx. single speed tranny, no CD
Dj_Sparky
09.06.2010, 11:56 PM
Did you check the things I listed? Might be an easy solution.
And did you manually turn the motor? Is the sound coming from the motor itself?
If it turns out to be the motor and you decide to open it, there's not really anything you need to know except to only use a reasonable amount of force with everything you do to it.
A RC Dude
A RC Dude's Avatar
09.07.2010, 05:56 PM
yea, you can't tell anything from the outside. and turning by hand it doesn't make a sound. it's only wile it's moving fast. it sounds about like a supercharger does on a car.
