I would be satisfied with about 60 mph, I dont think I would actually go 60 mph often, I just want crazy acceleration whenever I lay into the throttle. Big power and speed is more important to me but I want to be able to put that power to the ground, thats why I chose the crt, less rolls wheelies and flips than the emaxx.
http://www.amainhobbies.com/images/large/ofn30774.jpg
are these the shafts you are talking about? These are the optional ones, they are alloy, I beleve the stock are steel, I am not certain. I may try to find them in titanium or get some made in tool steel if they are a problem.
Originally Posted by Gustav
i think they end up only around 4kg RTR.The question is how fast do you want to go?i think 50mph is fast for an off-road truck but some people need more.
Also is lightweight and handling more important or big power and straightline speed.
For a racier 40mph setup i'd take a 1940,mount it above the spur in the centre and move the batteries closer to the centre line to lower the yaw moment.i think that would be the best handling.
For heavier motors,i'd mount it low beside the spur,due to the weight of the motor.
A 1950 would do mid 50s i would think,beyond that the 2240.
I'd be a little cautious about the alloy bevel shafts in the Jammin,i guess any BL motor will test these though.
Edit;nl12,since you have access to a machine shop it would be easy to run off a set of steel bevel gear shafts on a lathe if the alloy ones become a problem.
