Semi Pro
Semi Pro's Avatar
10.04.2010, 08:47 PM
Originally Posted by Freezebyte View Post
How could you loose a reciept for a $300 system? Anyway, I highly doubt the system will give a crap if you swap out the DVD drive. I've swapped HDD's in different Xbox's in the past and it worked just fine.
Now the matter of getting my game saves from my old Xbox via a USB stick to work on my new slim xbox has been....frustrating
nice to know you dont have a clue what you are talking about again
ok i will try and explain this if you want but you may have better luck watching people do it on youtube, you can learn alot on youtube, just look up "how to flash a xbox360". the only thing you will do diffrent is you are recovering the drive code from the bad xbox drive and flashing it to the good xbox drive, then if you want you can change the firmware on the drive or leave it alone
programs you need are
- jungle flasher
-dosFlash V1.8
