TCS Black XL TVPs
josh9mille
josh9mille's Avatar
TCS Black XL TVPs - 10.28.2010, 09:07 PM
Got these in the mail today along with the esc relocation plate. Man i cant believe how thick these plates are! And they look good installed on my beat up old truck! haha. However i cant decide how i want to mount the esc, either with the traxxas holddown or without. I kinda wish the plate was wider so i could have room to mount the trx holddown in any direction, seems like sideways is my only option unless i want to just use double sided tape and a ziptie. Have any of you guys used the TCS setup on your flux? If so how did you do it? Pics?
DARKWAV
10.29.2010, 05:01 AM
I'm right there with you man. I have all my parts out and plan on getting to it this weekend. The ESC plate wasn't available when I ordered my black TCS XL TVPs but I want to move it down low so I picked up the engine mount braces. My plan is to cut my own plate out of aluminum and use the TRX holddown. i assume there should be enough room to mount the ESC the normal direction since I'm not making a cutout like the TCS plate has for the power switch since the TRX holddown has a switch mount already.
thzero
10.29.2010, 08:39 AM
I have the 5T plates... so far so good. I think 5mm was a bit of an overkill, 4mm would probably have been about right.
I just used heavy duty velcro (http://www.radioshack.com/product/in...uctId=2103345# I believe thats it... ) to mount the ESC to the standard Flux ESC mount; but I also don't use the post that ties the mount to the motor plate.
DARKWAV
10.29.2010, 02:23 PM
5mm may be overkill, but that is what makes these TVPs cool. It seems fitting for this brutish truck to have a chunky overbuilt set of TVPs. I don't thing the drivetrain will be any worse for wear running these compared to other XL TVPs. I also really like how the screw heads are recessed into these. It is gives it a really clean, finished look especially when converted over to socket head cap screws.
josh9mille
josh9mille's Avatar
10.29.2010, 03:47 PM
Got the esc mounting figured out, just went with doudle sided tape and a ziptie. still look pretty cool, but i dont know why HPI orders these motors with wires that are 6inches long, it would look a lot cleaner with shorter wires but i suck at soldering so the long wires were tucked down with another ziptie. I need to get an extension for esc because no matter what way i route the wire it will not reach the reciever, only by like a half inch though.
DARKWAV
10.30.2010, 12:29 AM
Just one picture? Post-up more!
Knez
Knez's Avatar
10.30.2010, 10:40 AM
Well i do like the long wires on the motor.. if u want shorter u just cut..
Here my set up at the moment on my flux GCM XL..Must say Traxxas ESC holder is very good!
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
mac3194
RC JUNKIE!!!!
mac3194's Avatar
10.30.2010, 12:17 PM
how did u get ur mamba monster motor to fit in the stock flux chasis??
Knez
Knez's Avatar
10.30.2010, 12:37 PM
Sorry for offtopic...
Well i got TVPs from GCM Racing and size iz XL, i grinded the HPI motor clamps/holders to fit CC motor..
Motor clamps/holder i marked like this
Grinded
Here finished
One set of HPI clamps/holders where grinded for even bigger motor
Flux 5B CC 1520
1/16 Rally
My Youtube
mac3194
RC JUNKIE!!!!
mac3194's Avatar
10.30.2010, 02:10 PM
i meant motor mount but thank you would it be easier to do that or grind the fins down??
mac3194
RC JUNKIE!!!!
mac3194's Avatar
10.30.2010, 02:13 PM
and how much needs to be ground down for a 1515 2200kv??
Knez
Knez's Avatar
10.30.2010, 02:19 PM
CC Motor 1515 is 40mm and with fins is 42mm wich means 2mm to grind off on motor clamp or 2mm fins on motor... well i grinded the clamps as i didnt wanna grind the fins
Flux 5B CC 1520
1/16 Rally
My Youtube
mac3194
RC JUNKIE!!!!
mac3194's Avatar
10.30.2010, 03:06 PM
ok ill do that as soon as my flm xl tvps get here
DARKWAV
10.30.2010, 04:07 PM
Agree, I would rather grind on $35 clamps instead of hacking on a $150 motor.
LiqrSicc
LiqrSicc's Avatar
10.31.2010, 03:38 PM
+1. My 1518 looks horrible after my hack job with the Dremel and different grinding bits.
XXL 1717
SCTE 1512
XXX-S VTA
DX3R
  Send a message via AIM to LiqrSicc
