Thread Tools Rating: Thread Rating: 57 votes, 4.93 average. Display Modes
mistercrash
Guelph, Canada, eh!
mistercrash's Avatar
11.11.2010, 11:55 AM
Remember my little experiment in post #655? I spent a couple hours fitting LST XXL CVD shafts on my ERBE. There is still testing to be done, I will test on 6S with a couple of brand new Hyperion 45C/90C 500 mah lipos. The way I installed the shafts makes for a wider track, about ¾’’ wider so to get roughly the same track as before, I could use zero offset wheels. I only have ½’’ offsets so the truck is wiiiiiide.
Here is what I used.
- 4 Losi LST XXL CVD shafts (ebay)
- 4 15X21X4 bearings (Avid)
- 4 8X15X4 bearings (Avid)
- 1 set of RD Racing axles (Been running those since around 2004, same set)
- 1 set of Traxxas 17 mm hexes that have been bored to 8 mm with a 3 mm hole for the pin
2 Losi LST XXL diffs (I’ve been running LST diffs for a long time, details are in my thread)
- I used 2 RC Monster drive cups in the rear and 2 RCBest drive cups in the front, reason is, that’s what I had available. If the RCBest cups fail I will replace them with RC Monster cups.
I had a few 8X15X4 bearings from my LST that were gritty but I still kept them, I cut the outer race and used the inner race for shims behind the hexes.
Here’s the wide truck, either run it like that or use zero offset wheels or if you have the means to drill hardened steel then make a new hole in the right place to reposition the hexes close to the axle carriers.
Pic of the rear.
Here’s a close up of the shimming, two bearing inner race with two 0.3 mm shims on each wheel. I think the best way would be to make a new hole to bring the hexes close to the carriers. I will try it like that for now but I’m just worried of what this will do to the outer bearings.
A pic of what I did to pic up the slop of the inner 15X21X4 bearing in the RD Racing axle carrier. The perfect bearing would’ve had a 21”5 mm OD but I don’t think they exist so I put a piece of Gorilla tape around half of the bearing and it fits snug. Time will tell if the tape holds up. If not then I’ll use a shim made of thin metal like brass.
I'll probably find time to try it this weekend if it doesn't rain.
No brain, no headaches.
Currently Active Users Viewing This Thread: 6 (0 members and 6 guests)
