widemouthmaxx
widemouthmaxx's Avatar
03.21.2005, 08:05 PM
Originally posted by RC-Monster Mike
Higher voltage will potentially provide more power to your truck, but not your servos. If you have decent steering servo, the controller bec will give you plenty of power. For Aluminum 40 series wheels, there aren't a lot of options. I don't stock any, but can get some from my distributor. The ones there are quite pricey, though($200+ per set)!
200.00 bucks??? damn...I might as well ordere some proline shocks from you. BTW..I got my 9L today..thank you very much Mike.
A friend is going to help me wire everything up...
as for the motor wires and the esc motor wires..I can connect these in any order?
then adjust forward and reverse later via programing..right?
Also the UBEC that I got today (a local brand that is hand made)..can I put it in line with the reciever wires then plug into the reciever batt channel?
then what do I do with the black jumper?
In or out?
I did the read the sticky a thousand times regarding set up but I just want to be sure..thanks
