Inferno gt owners!! I need diff advice please
speedemall
Inferno gt owners!! I need diff advice please - 03.26.2009, 01:27 PM
What viscous diff fluid are you guys running in your gt's center diff? I got my car used and would like to change the fluid out for some fresh stuff.
03.26.2009, 01:29 PM
30k is what I use...
03.26.2009, 01:31 PM
spool...
streethot
03.27.2009, 11:11 AM
on inferno gt i used a spool, or locked center diff......
speedemall
03.27.2009, 12:47 PM
why is that??
03.27.2009, 01:22 PM
Stops power being lost to front wheels during accereration which will give you masses of wheel spin and torque steer...
streethot
03.28.2009, 08:19 AM
at on-road tracks I runned this thing with locked center diff the car was amazing......but several times the car went wheelies on the straights.......crazy........but fast.......with 50k oil it was great too........
speedemall
03.30.2009, 08:59 PM
I have used rubber silicone to lock diffs on many vehicles but not on anything this powerful should I use JB weld instead? I also found some 50k in my toolbox
nativepaul
nativepaul's Avatar
12.03.2010, 07:06 AM
spool...
I know this is a necro post but where did you get the spool from? I need a spool for my Hot Bodies Lightning 2 Pro carbon rallygame conversion, I know the diffs and diff gears are interchangeable with Kyosho inferno items and I am already running Kyosho spurs so using a kyosho spool seems like a much easier way to go than making my own which I though I was going to have to do.
Xray XT8, 1518, MMM, 4s5Ah.
Lots of boats.
fastelectrics.net
simplechamp
simplechamp's Avatar
12.03.2010, 03:17 PM
Kyosho spool should fit fine. Hot Bodies, 777/IGT/ST-R Kyosho, Jammin, and most Ofna diffs are pretty close in size. You'll always need a few shims anyway.
I am going to be using a Slipperential so if I'm going to lock it I need a temporary solution that can be removed at some point if I turn the car back into a buggy. Does the Ofna Diff Lock lube work any good?
