Thread Tools Rating: Thread Rating: 17 votes, 4.76 average. Display Modes
Knez
Knez's Avatar
12.03.2010, 07:05 PM
But as i tested those pink+yellow was much harder than with short springs.
Than again could even use 2x red spring..anyway...well i need to test the shocks on Baja first and than will see how and what.
So Thzero - ur 5b is like 8kg with 24mm hex and baja wheels, that is not bad at all!
Must also say, there is space for bigger motors...can use 1520 or 1717 in this kit as hole is big so motors up to 100mm can fit also 1717 diameter is not an issue here!
About the cups, that is what i ment...no bigger cups for center dogbones that mach gearbox and diff pinions..well i didnt make the kit, but i like the FAT dogbones!
At the moment i got 2200kv CC combo, motor mount was grinded, works perfect ! Will order than that 1520 sucker. I also got 5S and 6S lipos will test them both. Hope V3 will not go Puff-puff ...no pass! ;)
Well i like 1717 becaus eof its size, also everything in the motor is bigger, will take less heat and so on...but i dont like RPM max.
Oh, and here how i marked and grinded motor clamps..pic already been posted in another thread but anyway...
This set of clamps where grinded for even bigger motor!
Grinded vs. stock motor clamp.
Had this CC 2200kv and grinded clamps in my Savage XL
Also received a package today from a good RC friend, thanks bud!
...sorry for bad Q. pic.
Left : Turnigy S8166M 6V 33kg / .21sec / 155g
Right : MG995 6V 15kg / .13sec
Flux 5B CC 1520
1/16 Rally
My Youtube
Russian:Life and Trust is Lost Only Once!
