12.07.2010, 11:08 AM
If it has too much braking force, it could be the ESC is actually going in reverse when the truck is going forward. Many ESCs are MUCH more touchy on reverse braking than forwards. Swap two of the motor wires, reverse the throttle channel on your radio, then try recalibrating the radio and ESC. See if that helps. I'm not sure if it will work as I've never used/worked with the VXL ESC.
