Pdelcast
Pdelcast's Avatar
12.30.2010, 05:11 PM
Originally Posted by ksb51rl View Post
The pdf image on this Neu - Castle 1406 motor page (actual pdf link not working) shows the motors to have 3.5 mm bullets. I realize the smaller motor systems use the 3.5 mm connectors, but AFAIK the 1:10 and larger systems use 4 mm or 6.5 mm bullets. Why the change and which Castle Creations ESC are these motors supposed to plug-n-play with?
Thanx for pointing out the error! That document should show 4.0mm connectors, not 3.5mm.
Patrick del Castillo
President, Principle Engineer
