01.04.2011, 09:33 PM
Yeah, the big CC motor would be cool to do.
But I found out some rather depressing info today. Decided that I need to put some bulks on the 5t chassis and see what it would look like mocked up under the proline 5t body. Well I did that and ended up with a 19" wheelbase. The proline body really needs around 21-21.5" wb to look right. Will probably go with the redcat rampage body, as it will fit the 19" WB better.
Also had some issues with the rear hubs. They are atomic brand, and did not include new lower hingepins. They do have spacers, but the pin is too long as the stock carrier sits outside the arm, and this hub sits inside. I guess I will have to find some sort of suitable pin that is the correct lenght... BS if you ask me.
