B-Money
01.12.2011, 05:37 PM
More copies
Back to my new setup idea.
I have some questions and some more info.
1) i have two options for the motor mount/CD mount. I can either have the motor mount separate to the CD mounts or i can have the motor mount act as the support for the rear of the CD. I am going toward the idea of having the motor mount act as the rear CD support.
2) I am also thinking of adding some extra strength to the motor mount. As the motor will be at least 25mm above the base of the motor mount i am thinking of having two triangles on either side of the motor. This will add some serious support to the motor mount while still allowing the motor to be raised and lowered fully. (i'll post up some pics to show what i mean). My question is; Can aluminium be welded? Does welding things add alot of weight (the weld)? Does anyone in brisbane, preferably someone from PHDR (easier to meet up that way) know how to weld (stupid question) and would you be willing to weld something for me? Also how hard is it to learn how to weld and also how much would a basic welding unit cost?
I think that's it for now but i am tired so my memory is not all that flash ATM.
Long story short no sleep for ben last night.
I was bored so i did some measurements to fin the min and max pinions for my new motor mount. If i run the 1717 i think i am limited to about a 12t pinion and i can go as far as about 30T if i want to.
I have downloaded a trial for AutoCAD and it has helped alot. I did most of the measurements by hand but if i had've used AutoCAD from the start it would've been heaps easier.
The mount i am planning to make. The angle alu is 80x80 6mm , thanks Snap, the side triangle like supports will be made of 1/10" alu and will be screwed on with M3 screws.
The motor in it is the same diameter as the CC 1717 and is at its lowest point. The big flat cylinder is the spur gear and the long thin cylinder is the diff outdrive. As i don't have the proper measurement for it i am using the bearing that is a little bigger than the outdrive.
Just thought i might mention this here.
LD wanted to sell his XXL and guess what... i bought it.
I have some serious plans for this. I have ordered a mamba XL esc and a leopard 4082 1500kv motor.
What i plan to do is run this motor or my CC 1520 with the mamba xl with a TDRC mount and with 8s lipo.
This is another reason why i'm not doing my e-maxx chassis thing.
Well be prepared for another back flip.
...here it is...
I have decided to have the motor mount separate to the diff housing/supports. This will make making the motor mount heaps easier and better IMO as pinions will be easier to use (i can explain further if you want). Also in the pictures of the motor mount i have used a 80x80 piece of angle alu but seeing as the CD will need to be in the middle of a 120mm plate i will need to remove some material to make it all fit. the idea will still be the same with the two triangles supporting the motor plate.
Also for the rear motor support i will have the support posts mounted on the upper plate. My idea for this is to make 2 support plates. I will be doing one for the 1717 and the other to work with STD 42mm motors. This will mean that rather than the motor support supporting the motor in one little place it'll be supporting it through the whole lower half of the motor.
not sure if i have mentioned this before but i will need to make a new upper plate as the current one is a little too weak where the current motor is and it won't look as good with the new setup as the new plate will.
I will need to make a new CD upper support plate but this will not be connected to the motor mount as it wont be needed and will add useless weight (i hear some of you saying... what about the triangles...useless weight) but to me they are less useless. Also they should give the motor mount a good look as the two triangles will somewhat shield the motor.
Time for another late night/early morning speel.
I am thinking about buying a mill as it'll allow me to make higher quality bits and pieces than what i can make currently. I know i will use this but to me it seems like a bit of a waste of money if i am the only one using it. So i have been thinking that maybe if i can make some other mounts for people then my purchase will be more worth it.
Another option for me is to make my motor mount out of steel rather than aluminium. There are a few things that i am unsure of about doing this though. 1) steel is far heavier than aluminium 2) steel is cheaper than aluminium 3) Steel unlike aluminium can be welded with something other than a TIG welder.
I am thinking that i will buy both a mill and a welder (most likely arc) as it will make me sell off a few kits so that i have enough money to buy both. From what i have read you can buy a mini-mill for about $600 and a ARC welder for about $150. This'll mean that i will need to sell off a few kits so if you are interested in buying one of my kits PM me and i'll tell you if it's available.
i probably should've posted this in my blog but CBF'ed
That's it for the copies.
If you have any questions feel free to ask and i'll try to answer.
Thanks,
B-M
