01.18.2011, 06:18 PM
Maybe, but the output cups on the diffs are a little shallow, so the cvds may popout if you dont screw the pillow balls in. Most guys tend to change the output shafts/ cups to something longer/ deeper, or use the rc-m output shafts to fit deeper traxxas drive cups. Mike is out of shafts at the moment, but you can make your own using traxxas part #5454 & cut off the threaded part.
