Originally Posted by Dj_Sparky
Good deal sounds like. Do you buy materials locally or online? I've been looking for some cheap materials. Want to try making my own stuff as well.
And it's odd that you had to sand the GH bulk. I thought all the Savages shared the exact bulkhead/diff area dimensions.
I just go to ebay, best prices i have seen so far.
The bulk was not made correctly, that is why i had to sand it.
Originally Posted by Jahay
the only problems i had with my bulks were that the threads for the sway bars were not tapped...
They will definitely hold up to the 1717 power. THey are awesome bulks!
Good to hear.
Originally Posted by thzero
The TCS Crawlers TVPs are about 5.25mm, probably a bit of an overkill. I'd say 4mm is probably ok.
I'm trying out 3.5mm carbon fiber myself.
Sounds like fun. I am not really familiar with cf
4mm alloy would be plenty! 5mm is definitely un necessary!!! added extra weight too...
Yeah, I was worried about the extra weight, especially since I might not cut alot of windows in the chassis.
