asheck
03.03.2011, 08:16 PM
Sounds fishy to me Asheck. Both testing out to be within one amp of each other. What amps is the ET rated for again? OTOH did it weight less with the 3s?
I do only have the 100amp version, but I think it's still pretty accurate to about 125. No, the 3s weighs substantially more.
But here's another run. Geared 13/54 SPC 8000mah 2s , radared at 41mph
Full run was 5988mah, and the lvc had not cut in. Pulled 117.35 amps.
Temps were 125 esc and motor, with ambient of 64
An expanded view of the first 4 minutes.
I am really curious to see how the drivetrian holds up to that power over time. If it holds up and doesnt self destruct it would be an excellent backup basher to my savage. It seems to have the same driving characteristics as my savage but in a much lighter and cheaper to operate package.
Me to. All I can say is I've been pretty rough on it, and it's going strong. These tires make this truck. I'm so much happier then with the other tires I've tried, Talons, 30series Badlands, and Losi 320s Zombiemax tires.
