03.09.2011, 02:59 PM
Originally Posted by TexasSP View Post
Parallel will give whatever the input voltage is to each motor, series will split the voltage in half.
So if parallel and 12v each motor sees 12v, whereas series and 12v each motor sees 6v. This is for two motors only. If series is three motors each motor would see 4v.
Yup, so parallel is what I want, get the max rpm I can out of these turds.
Vehicle weight will not be much, less than 5lbs, and top speed of 25mph will be just fine.
