B-Money
03.17.2011, 02:46 AM
So,
i raced this on sunday. I was hoping it would be an awesome day but it wasn't. All throughout the day i was having issues. I think i only finished one race out of about 5. Throughout the day the motor kept coming down on the spur making the mesh seriously tight to the point that it felt like the drag break was enabled and at 100%. This was with the 1717 so i may go back to the leopard motor (another reason later). Also i was using a RC-M slipperential. It is basically a CD with a slipper built in to it. I'm not sure what was happening but it was loosening through the day. So i think i may just go back to a normal CD that has no slipper. Not sure if i mentioned this before but i am not using the stock LST servo savers as they are crap. So i bought a MGT servo saver as people have said they are great. Well it made my steering terrible and just fell apart during the day. So ATM i am using a straight link between the servo and steering. This will mean that i will have to replace certain parts more frequently but unless i completely re-do the steering i cannot think of any other way of doing it.
Also as mentioned above i was running a CC 1717 motor and the MMMXL esc. This setup was good an neither were getting hot but my runtimes were seveerly reduced compared to any other setup i ran. I don't actually think i could last the main (12 mins) with 5200mah.
So i am now thinking of going back to the leopard motor, with the MMMXL esc and possibly getting it setup for dual 4s 4000mah lipo's.
i am also thinking of making my own battery 'boxes' as i do not like the flux ones. I have the basic design but am wondering if i should make as much out of CF (but still use some Alu) or just make the whole thing out of alu.
Also, should i remake the upper and lower plates out of CF or leave them as is.\
I would love to race this but ATM reliability is an issue that i cannot overlook. The previous time i raced it i still had issues but it was wonderful to drive, so should i persevere with it or just give up and race my ERBE.
Sorry for the long post and i appreciate any advice/criticism.
el tomaso
03.19.2011, 05:55 AM
Great project, but you seem to have lots of bad luck with small things. I would use locktite more. On the motor mounting screws, and on the pinion grub-screw. Out of all your motors and esc's I would use the leopard 1000kv on 8s with the MMMXL, so you get what you paid for from that esc. Then have the 1717 on 6s with the MMM in the XXL with TDR mount.
Just my two cents or whatever.
TG
B-Money
03.19.2011, 06:03 AM
TG
i think most of the locktite issues were from when i was originally putting it together and didn't use locktite as i thought i would still have to pull it apart.
I don't really like using locktite on the motor mounting screws. not sure why but never done it. i think most of the issues with the motor coming down onto the spur were due to the washer i was using. It was far too big for the screw but was the only one i had and that may've cause it. I think this was the issue as i didn't have that issue with the leopard motor that didn't use a washer due to the screw type.
i recently bought some turnigy nanotechs (4s 4000mah) to use in parallel but i guess i could use them in series. but i plan on racing this and i'm not sure if 4000mah will last 12 mins.
Also, i have torn down my blue LST. I did this as it didn't handle the way my original one did and the previous owner did some weird things with it. Also i shredded the rear diff and ATM i CBF'd ordering a new one.
Also, earlier today i made my new battery boxes. These are about the same weight as the flux ones but should be heaps better and easier to use. Plus this means that i can go back to using the MMMXL without it annoying me.
Not sure if i mentioned this here but i have gone back to the leopard motor and the leopard/hobbywing 150a esc.
B-Money
03.19.2011, 08:54 AM
just spent around the last 2 hours changing over the chassis rails, the ones i have now are not stripped and i have gone back to the imperial screws. For the load bearing screws i have gone back to the imperial ones as they give a better 'bight' into the plastic, this is mainly because the rails have already been tapped for the imperial screws.
why of why can't losi go to all metric screws. (just kidding but seriously)
