Thread Tools Rating: Thread Rating: 58 votes, 5.00 average. Display Modes
brian015
brian015's Avatar
03.30.2011, 07:25 AM
Originally Posted by thzero View Post
Hope it does what you want but I'm not sure it will help; the forces should be on the outer and inner bearings because that is where the flex points on the axles will be I would imagine.
The way these fail is that the force on the tire/wheel pivots the axle on the outer bearing and the skinny 22mm inner bearing fails. Anything that can help support the axle on the inner side of the outer bearing should help these sustain that force.
Josh - I agree that having the third bearing closer to the inner bearing is best.
