ZippyBasher
8th scale Stunt-Driver/Mechanic
ZippyBasher's Avatar
04.04.2011, 09:04 PM
Nice Ride there zues. I like the Body/Cage. I am digging all the stretch projects around here. I did one but based on a Rustler so only 2wd.
You still have a weak point in those diffs with the plastic diff cups. I would have just changed them with an aluminum diff cup while it was apart. There is still too much chance of flex once you put those diffs under power with that motor and those gears are going to eat themselves at some point and may damage your new diff cases along with them. Sorry just had to point that out. Why only go half way with the upgrade?
I have been there and done that with the LST2 cups. IMHO, The HD Plastic cups are better than an Aluminum cup. You can see my thread how I just have gone through a set of Al cups in 1 run in my 13lb Maxx. Reason being is the HD cups have metal inserts and spread the bevel pin load over a greater area. The metal cups are machined after the old Non HD cups. The pin eats into the sidewall of the cup and then it toasts the bevel gears... What we need is a machined version of the HD cup with the metal inserts. Then we would be bulletproof as the Ring and Pinions are tough as hell. Mine look brand new with over a years use.
EDIT this is pasted from my Thread:
Originally Posted by ZippyBasher View Post
I thought the same thing about the Aluminum Nova Cups Being bulletproof. The rear cup is useless after 1 pack and I just took the CD cup out to refill with a lighter fluid and give it a thorough inspection and it actually is starting to wear pin slots in the side of the cup as well...(at least a dozen runs or so) I can try to get a picture but Its not that cool Well there goes $40.
I will just go back to the Losi XXL HD plastic cup. I looked at the one I was using for over a year in the rear diff and it looks new... the ring and pinion also look brand new. I guess those little metal inserts in the XXL really save the cup. I think a CNC cup designed after the XXL cup would be bulletproof, but not cheap to get CNC'd...
Maxx - FLM, MMM, CD Med.36x706s
Raja - FLM Ext. MM, 1512, 4s
SC8ight - MMM, 1520, 6s
D8T - MMM 1717 6s
My OVERPOWERED Rides "CLICK"
Like Playing Cards? Cut-Throat Rummy "CLICK"
