Castle 2650kv side free play
bymannan
Castle 2650kv side free play - 04.04.2011, 04:33 AM
Is this normal? It is a relatively new motor.
[YOUTUBE]c2YeOAu6lGQ[/YOUTUBE]
I've sent this to Castle support email with no reply. So much for support.
Hyper-5
The-Hyper One
Hyper-5's Avatar
04.04.2011, 05:50 AM
my motor does tha same thing, lm not to sure about it but wen l pulled my motor apart to see somthing, ther pole was stuck on the side cause its magnetic, lm sure someone else has a better answer than me though, not to sure
soz
speedy
04.04.2011, 11:17 AM
That's not normal ! I think one of the ballbearings are busted !! There chould be no sideplay on themotor shaft !
kievyu
04.04.2011, 11:51 AM
bearing or bearing housing damage .....
nvtuning
04.04.2011, 12:19 PM
replace the front bearing or you will f*ck up your rotor like me if you haven't already
greets nvt
rc8te/NEU 2200kv/mamba monster/4cells lipo
savage/castle 2200kv/mamba max pro/4cells lipo
scx-10/castle 4600kv/mamba max/2cells lipo
bymannan
04.04.2011, 04:25 PM
Yeah, looking closely the bearing seems just fine, I think the bearing housing is bad. Maybe it came out like that from Castle, can be sure.
Will the repair kit cover this?
http://www.gshobby.com/index.php?mai...ducts_id=22803
Thanks...
nvtuning
04.05.2011, 03:41 PM
the repair set wil cover this but i realy think its the bearing i also got that and the bearing is realy worn out
greets nvt
bymannan
04.05.2011, 05:19 PM
This is odd, this motor has 6 runs in it. Anyway, maybe I should replace it with something better.Any recommendations?
nvtuning
04.05.2011, 05:28 PM
i got it with a motor that only has 3 runs ;)
i hope castle warranty's this
greets nvt
niklass
04.07.2011, 09:53 AM
If youre adjusting the gear mesh to tight you could end up with that problem in half a run.
nvtuning
04.07.2011, 09:55 AM
my gear mesh was perfect and loose i put a paper between and checked with my eye ;) and feeled with my hand by turning it a little bit
greets nvt
nuz69
nuz69's Avatar
04.08.2011, 09:53 AM
The bearing is glued in his housing. After some run (100-150 batteries for me), the glue does'nt glue anymore and you have to reglue it, other than that the housing will take some play (but not immediatly).
Anyway it's not normal to have this kind of side play after a few run.
Inferno VE MMv3 NEU-CC 1515/1Y 4S "Flying machine"
MBX5T Prospec MMv3 NEU-CC 1520/1Y 6S "Overkill Flying machine" ;)
Brushless, what else ?
