Originally Posted by magman
Yes, its the RCM Revo mount... http://www.rc-monster.com/proddetail...&cat=33...Well, so far w/the 2 battery set up, I can get 15-20 minutes run time...sometimes more depending where I am running. In the smaller parking lot 20minutes+, in the larger one where more wide open throttle is required a little less
I was told it's very expensive to run this 1/8 on road Ep. No traction as it need caster oil on the ground, need truing of the tires?
Hv u tried 4s with higher kv motor?
