Originally Posted by nuz69
I say, why not ? The amp draw doesn't depend of the motor but depends of the setup.
The motor weights 1,3kg, if its put in a monster truck of 4kg, it will do 5,3kg total weight. Geared for less than 50mph, the MMM should be totally fine, the MMM is enough to push a 5kg vehicle to more than 60mph with 6S lipo, so why not ?
More over the 2028 has a small Kv so high inductance, then the current spikes should be very low compared to other setup with smaller motors...
Just my opinion...
It has the potential to pull more amperage than the MMM can handle. It is just not a wise setup.
You could run it on a sidewinder but I wouldn't do that.
