simplechamp
simplechamp's Avatar
05.06.2011, 02:19 PM
The Kyosho 2-speed setup is longer than the normal center diff setup. You would have to drill out another pair of holes in the chassis to mount and find an appropriate (shorter) sized dogbone or CVD. You would also have to give up reverse and switch to a mechanical brake setup (unless you already have mech. brakes)
